I would like the ability to do some basic measurements and plots of my system. I want to be able to do nearfield speaker frequency response measurement, and subwoofer (even below 20Hz) measurement. I would also like to be able to look for room modes and nulls at the listening position. It would be neat to look at waterfall plots of decay time as well to see how lively my room is. If possible, I would also like to be able to create spectrum plots from sound files on the computer, but this isn't a priority. I realize that not one single software package will do all this.
I currently have: a Radio Shack SPL meter and Room EQ wizard. I haven't used REW out yet because I haven't finished building the speakers, thus nothing to test. If I wanted to step up to something a little better, what should I consider?
I see a bunch of inexpensive DIY measurement mic plans online based on the Panasonic electret capsules. Are any of these a better value than simply getting a $50 Behringer ECM 8000? What other budget measurement mics are worth considering?
Either way, I will need a mic preamp. My only PC in the house is a Dell laptop, with a less than spectacular sound card, so I am assuming better ADC would behoove me as well, so now I am looking at the $150 M-Audio MobilePre USB. Is there anything else that would get me a quality mic pre-amp and USB computer interface for less money?
Then I'm sure there is better software out there. TrueRTA is $40-100, ETF/R+D is $150-300. I'm not currently looking for driver measurement software like Praxis or CLIO, but I'm aware that there is plenty of high dollar software out there. I'm just looking at the budget stuff.
So what capabilities does spending an extra $200-500 afford me above REW and my Radio Shack SPL meter?
Any other recommendations? Thanks.
-- Cameron
-- Cameron
