After nearly killing myself getting 2 17^3 net MDF enclosures out of the house I'm going to build a new one out of BB to save some weight and change the dimensions a little. They had to be near 350 pounds each 8O
Old enclosures were 1.5" thick, each housing 2 Tempests and had a simple 2" wide brace near the middle connecting the sides & front/back, so like a + sign. Never had any vibration issues, enclosure was rock solid.
So what are the pro's/con's of doing a 1.5" thick enclosure with minimal bracing vs a .75 thick enclosure with window bracing? I'm sure the 1.5" will be heavier, but the window bracing seems much harder to calculate displacement and a lot more cutting/routing. Any other things to consider?
Will be picking up the wood Saturday when I can get a friend with a pick up to help. This will be for 2 RL-P 15's, single 10" port, 34x24x46 dimensions.
