First off I'm new to the forum and have spent the past few weeks searching/reading and have found a lot of good information. Seems like a good group on here.
I have a pair of D4 RL-P's that I'm taking out of my car and want to use for HT sub duty. Here's what I'm looking at doing using existing stuff I have unless there's a huge advantage to porting lower.
Each sub will go in 10^3, 6" port tuned to 17.5Hz and be downfiring. I already have 2 big enclosures housing 4 Tempests, so I'm going to cut those down some and make new baffles. Boxes are double walled/braced and lined with batting.
The 6" PVC is 20 1/2" which would give me a 17.5Hz tune. Obviously I could get longer PVC if a lower tune would be better, but if this will work I'd just use what I have. Subs will be 70/30 HT/music. I'm not looking for a low end killer per say, just some very solid output with lots of impact.
Currently have an old Hypex amp that does 800watts @4ohm, and I'm guessing that won't be enough to really push them, so I'll probably pick up an EP2500 to power them.
Pros/cons of front firing vs downfiring? Floor is laminate over concrete and the subs will be in a corner about 6' from listening position.
Any suggestions/feedback is greatly appreciated....
