From what I've read, it appears that lining a sealed enclosure (both speakers and subwoofers) with felt, sonic barrier, whispermat, or similar materials is a waste of money, compared to stuffing with fiberglass or polyfill. This is because you don't have to worry about standing waves escaping the box (no vents), and stuffing does an adequate job doing thermal absorption. The only problem left is panel resonances, which in a properly braced box, are not a problem. The panel resonances are even less of a problem in a subwoofer, since they are generally outside the passband, if considering a typical 80hz crossover. However, you still need to have good bracing, not because of panel resonances, but because you want to avoid efficiency loss.
Is there any misinformation in the above, or am I missing any critical information or gotchas?
Thanks!
Thanks!
