Recently I've been designing a linear regulated supply for op amp ckts as many have read in other threads. One thing that's been ticking me off is the gross inefficiency of these things. It sucks! But I never gave much thought to SMPS in audio apps. They always spec something like 1% p-p ripple, which I thought was totally unacceptable in audio applications. And using a post regulator after a switcher just doesn't appeal to me, especially since their RR ratio >100KHz is poor and getting poorer at a steady rate. However....
At work the other day, I put the scope on a 50W Astrodyne isolated DC/DC converter (half brick). I was amazed at what I saw. In scope mode, it had about 100mv of ripple at 200MHz measurement bandwidth, about half that with a 20MHz bandwidth limit, and virtually NOTHING, maybe 1mv ripple, with a 10kHz bandwidth limit. (Those limits are the only options on my scope, a Fluke 199C). Looking at the waveform, it had noise bursts every 2.5 microseconds (switching frequency of 400kHz I guess). These bursts were very, VERY noisy, and died down within about 1uS. Putting the scope in spectrum analyzer mode, however, showed most of the noise up in the 10-30MHz bandwidth, which I thought was interesting - nothing really at 400kHz. Now I don't totally trust the spectrum analyzer of this scope, as it once told me a high quality 16MHz crystal was operating at 16.7MHz (though it did show a nicely decreasing sequence of harmonics). But I do trust it to get things generally in the right range I guess. (Putting it back into scope mode and telling it to measure frequency gave a dead on 16.0MHz for the crystal).
Anyway, I was wondering what I need to look at with SMPS to determine suitability for audio. Do I care anything about noise >20kHz? >100kHz? Up to the GBW product for the opamps I am using? How much can be dealt with using bypass capacitors of a wisely chosen size?
I have a smaller +/-15V Astrodyne coming in early next week for the same project and I am sure going to measure the hell out of it. These are just a little pricey at 30-40 a piece, but man are they tiny, and the ripple in the 20KHz bandwidth could effectively be nothing.
Also, if you SMPS guys have rec's for companies other than Astrodyne, I would be totally open to suggestions. That's the brand we frequently use at work so that's what I can easily get experience with without spending my own money.
Also, I should mention I am very much being an engineer and not an audiophile about this - I do care very much about sound, but if the measurements tell me this is satisfactory, I am going to run with it.
