I remember reading somewhere that fiberglass resin was better than caulking because it does a good job seeping into the cracks. This stuff (fiberglass resin) is not very viscous at all. If you were to use it on two sides before it sets, one side would not be covered very well, since the resin would slide out of the cracks and down the side. Do you mix it with some kind of filling compound (MDF dust?) to make it more viscous, or do you only use the resin on one side at a time, letting it dry before moving to another side, in order to avoid the dripping/movement?
Fiberglass Resin?
I think resin was suggested after assembly. Pour a bit into the corner and move your cabinet around to get coverage on the inside of seams. Similarly, you could brush/roll it on the outside of a cabinet after assembly to seal up the raw ends and fill the seams.
Polyester resin isn't the best glue if you want to glue your boxes together with resin. If you want to use epoxy there are various fillers available. See WEST System and System 3 (two brand that come to mind, I've used WEST on a boat) Good old yellow glue is plenty strong enough, though.- Bottom
I got convinced to buy the West System by the sales staff at a fibreglass supply store.
I haven't used it yet but they advised that the epoxy had a low viscosity so the sold me some "microfibre blend" (looks like powdered glass) which can be added to thicken up the epoxy.
The West system may be massive overkill for the task, there maybe cheaper options.
It was my impression that epoxy is used in speaker building for it's sound deadening properties rather than something like superior strength.
Regards
John Q- Bottom
