We had a discussion on the merits of the XG18 and XT18WH a while ago. Well, the XT18WO was just tested. The WO differs from the WH in that it has a larger magnet and a Kapton former.
Impedance has a little wiggle at 400 Hz and 1.4 kHz each. FR is very flat out to 3 kHz with no signs of the surround mode dip so common in paper cones. Actually, FR is +/- 4 dB flat out to almost 10 kHz!
CSD looks good for a paper cone but messy compared to good metal cones.
Distortion is really quite good! At 90 dB/1m, 2nd is around or below 0.3% 100 Hz - 10 kHz, 3rd is at or below 0.1% 120 Hz - 2.5 kHz with an occasional excursion to 0.2%. 5th is below 0.03% anywhere above 100 Hz. LF distortion, the Archilles' heel of the XG and XT18WH, is average for a decent 7 in driver: 3% 2nd and 3rd at 50 Hz.
