I'm without a windows machine at the moment... Anyone mind posting some graphs for a big 'ol LLT design?
EBS design with Mach 5 IXL-18.4
Originally posted by GirI'm without a windows machine at the moment... Anyone mind posting some graphs for a big 'ol LLT design?
Gir, here's a quick shot of what this thing will do - 15 cubes tuned to 15Hz. Will reach Xmax with ~500 watts of power; 3db down at 17Hz.
Best,
Mark- Bottom
Originally posted by ThomasWThe so called LLT is nothing but a standard EBS design that's been renamed and given magical performance characteristics. There are several examples of these in the gallery pages and a forum search will bring up a ton of threads about them. Also this is a topic for a separate thread.- Bottom
I just got onto my friend's computer and ran some simulations. LLT of 800 L tuned to around 12hz looks good. Only problem is that it's 800L. With 28" sonotube that would take about 6'8" tall. With 32" sonotube we're talking around 5'1" tall. Other problem is that it hits max excursion only after around 175 watts. Do you think this would be worth it?
[EDIT]
Sorry, I'll run a search.-Tyler
Under deadline pressure for the next week. If you want something, it can wait. Unless it's blind screaming paroxysmally hedonistic...- Bottom
You can drop the size down to 20 cubes and tune to 14Hz with losing about 1Hz. At 500 watts you are pushing excursion slightly over Xmax which shouldn't be an issue.- Bottom
You can drop the size down to 20 cubes and tune to 14Hz with losing about 1Hz. At 500 watts you are pushing excursion slightly over Xmax which shouldn't be an issue.550l@14Hz@350W is 112dB@12Hz while running 0 overexcursion risk (never goes above 20mm)
Think I should go for it?-Tyler
Originally posted by joecarrowIt makes me wish I didn't live in an apartment, that's for sure!-Tyler
