Currently have a pair of Dayton BR-1's, a 12" sub with a dayton plate amp, and an old 2 channel denon crappy amp/receiver.
Looking to get another pair of bookshelf speakers
I have about 150 to spend on some sort of amplification set up for all this:
I have heard good things about the Teac digital 3-channel amp that can be had for about 100
good things about the sonic t-amps
I am also interested in DIY amps that are cheap similar to the gainclones (can one of these power a pair of bookshelves??)
or just buy a better used receiver off craigslist and call it good
could I send the signal from my old denon into the plate amp then out to the sonic t amp or gainclone then to the bookshelves (also would the signal already have cut out low frequency bass so the sonics would have "less to do" and get the bookshelves fairly loud and clear) Right now that is the setup I am inclined to go with, any pro's con's to doing this (since essentially the signal would be amplified through the crappy denon then again through the plate amp then again through the sonics...or when routing a signal through the plate amp and out to the speakers is it not amplified??...)
I know this is alot to swallow and probably sounds a bit confusing but thanks for the help
