oops
How far off the floor should I lift my downfiring subwoofer?
3"-4"
thanks for the reply
Thanks for responding to my brief question. I had deleted the post because I deemed it unworthy, as I could just tinker around with it and figure it out once I get it running. But your response of 3-4" was much higher off the ground than I would have started, and probably higher than I would have ended up doing. So thanks, and here's a little more about the application and a couple more questions if you don't mind.
It'll be a 13" sub running on an edesignaudio 1300w plate amp in a ported box that was originally designed for a car application. The woofer is a kenwood kfc-xw1300dvc dual 6-ohm driver that just eats up power from what I learned from the only review I could find on this driver:
As the above review praised the driver to be only slightly better than mediocre (7/10), my expectations for this application are not grandiose. The port, constructed of 3/4 mdf, is vented on the baffle so will fire downwards as well. I am not sure of the box tuning. Once the amp arrives, I plan on making this box that was born into a car feel more at home by slowly feeding him some polyfill.
What kind of feet would you recommend for a wood floor? The 16x18x34 side-laying box with woofer and amp must weigh at least 150#. Double layered 3/4 mdf on the box. Ideally something that will not damage the floor. I plan on burl laminating the enclosure if the experiment is a success.
Would placing a rug under the sub be a good idea? My 12 x 18 theater room is wide open, with a 4x8 portal leading into the dining room and on to open doors to the kitchen and bedroom. I have no specifically designed acoustic dampening, and what little furniture I have is leather. I'll be running a behringer dcx2496 to crossover and fine tune it.
So... what kind of feet -- wooden vs rubber vs ...casters?? how about a rug?
Thanks again!!
Zac. :B- Bottom
I'm sure you're aware the driver is designed for dB drag-racing not home audio. Given it's pricing my suggestion is to sell the driver and buy one more appropriate to your real needs...
That said you can buy premade wooden legs at the home center stores. Or people just use big dowels. There are nail-on nylon glides that will protect the floor.
No need for a rug.
I'm not sure what you mean by "slowly feeding it polyfill". The walls of ported boxes are lined with damping, they're not stuffed like a seal box
you're probably right
I imagine you're right and I will probably end up selling it off... most likely as a car sub. But since I inherited it I thought I would give it a run in my livingroom just for fun. I'll probably just use some mdf scraps glued together for legs then. thanks for the input!- Bottom
walls lined with damping?
not that I can see. there's no damping in this box at this time. That's why I want to line it with polyfill. maybe that's why it sounded like crap when I heard it in the car. I figured it was because it was underpowered or just wasn't suited for that vehicle.- Bottom
Isn't it theoretically correct, that if you lift it up to mid-height of the room, you eliminate another possible room mode? Thought I read that somewhere, like it is the basis for the ASC Sub Stand.
Therefore, I say lift the sub 4 FEET off the ground.- Bottom
