Hi all,
I'm wondering what you all would recommend to sandwich in between if you wanted to use a 3/4" hardwood baffle over a 3/4" mdf backer board to inhibit baffle vibrations, seal the cabinet, etc.
The baffle would be floating and held in place with something like socket head cap screws and hurricane nuts glued and screwed into the mdf.
Anyone have some suggestions?
