I'm trying to plan for my first 3way design and am concerned about CTC distance and the crossover points that this suggests.
In my case I'm doing an hybrid omnidirectional. It may have two woofers, firing up and down at each other and two mids firing similarly. The tweeter will be front firing, perhaps with a waveguide and rear firing tweeter (see the prelim plan below.
Here is my concern. When you have pairs of drivers, how do you figure the CTC distance; from the nearest two drivers, the furthest two or from the middle between them? How about in this application where they are up and downfiring?
Secondly, in my prelim looks at it, I get the idea that in order to get the drivers in proper CTC distances, that I can't get the crossover at a good point to avoid mid and woofer floor bounce cancellation. They seem to fight each other, unless I'm missing something (probably). CTC would suggest a max distance of 18" for a 750hz crossover. For example (using BoxyCad2) if I have a ear height of 37" and a distance to listener of 11.5', if my mid is at 35", then my woofer has to be at 9" to get a recommended 750hz crossover, for a CTC of 26". I have to lower the woofer to under 29" and have the woofer at about 11" to get a good match between the two. If the tweeter is within 6" of the woofer, that puts the tweeter at only 35". That seems too low for both. Shouldn't they both be near ear height? :??
Can anybody give me some guidance with these questions? If they do fight each other, which is the most important to go by and how do you resolve these seemingly conflicting issues in a design?
Thanks!
Thanks!
