on an inductor (air core coil), which end is the gozinta and which is the gozouta?
I wired mine with the wire coming from the inside of the coil as the "in" or "from source" and the outer wire as the "out" or "to driver"
is that right? backwards? matters not?
wrt the resistors and caps, I wired them so when reading the lable printed on the component, in is on the left and out on the right.
again, right, wrong, who cares?
