The Slanted Monoliths: a project using Peerless Exclusive & 27TBFC drivers
  • fjhuerta
    • 1140
    Hi!
    I thought I may start posting about my projects. I think I've just (barely) got the hang of this speaker design stuff.
    The first project I'll try to document are the Slanted Monoliths, which will be a:
    1) Slanted tower
    2) 2.5 ways
    3) 2 830884 Peerless Exclusive 8" drivers per side
    4) 1 Seas 27TBFC tweeter per side
    5) Aproximately 100L in net volume (?)
    6) 2" baffle, 1" enclosure, MDF, with a 6mm veneer (maple?)
    There are still a couple of points I haven't decided yet, though. Here are the unknown variables:
    1) Should I stay with BassBox & LSPCad, or move towards SoundEasy?
    2) Sealed or ported? Those Peerless really need massive amounts of internal volume if ported (well, massive compared to, say, a Natalie).
    3) Crossover frequency? I'm aiming for a 1.5 KHz filter. I wouldn't know how to implement a C-E filter here (with the added .5 woofer, that is), so I guess I'd use a 4th ~ 6th order L-R acoustical. I suppose it's not a big deal, since the Exclusives don't have resonances as strong as a metal cone.
    I'll try to design the enclosure this week. So far, I'm looking at a 1 meter tall, 50 cms. deep, 33 cms. wide enclosure (not exactly what I'd call "small") with a 6° slant on the baffle.
    So I guess I'm all set. I still wonder how am I supposed to measure the baffle on-axis... is it on tweeter axis, or should I raise the mic a bit and point it towards the tweeter at 1m?
    One other thing - I measured impedance and T-S parameters of tweeter and woofers. One thing I noticed is that the woofer's Le is way off spec on each of the 4 units I tested. I wonder if there's an error on Peerless' spec sheet.
    Will post the parameters later today...
    Javier Huerta
    • 15298
    Le is not a linear property- you'll usually find when you measure it that the inductance value you get depends on the frequency you measure at.
      • 5204
      Hey Javier,
      Is this project finished? I came here looking for a photo to add to the Guide to... thread.
      • fjhuerta
        • 1140
        Hi K, I think I gave you a wrong link... the project is indeed finished. Let me find the thread.
        Javier Huerta
        • fjhuerta
          • 1140
          Here you go..
          Javier Huerta
            • 5204
            Yeah, that's better. I knew these were finished. All fixed.
