NS15-992-4A vs. any other highend 15" subwoofer
  • John D
    • 26
    I'm interested in using the Aurasound NS15 in an active closed subwoofer with some EQ. The driver looks very impressive. However, I'd like to know how it compares to other 15" subwoofers. For example, Dayton RS series look rather impressive too.
    I realize the Aurasound is rather expensive and I have no doubt other manufacturers offer higher value for money. I'm looking for the best available though.
    Does anyone have comparable measurements of the Aurasound and other advanced 15" subwoofer drivers? Thank you very much!
    John D
  • John D
    • 26
    Anyone? :P
    • Mazeroth
      • 422
      What has drawn you to the NS15? It's probably a great driver, but for $600? There are many other drivers that cost half or less with more output capabilities, which you'll need if you intend on EQing the low end in a sealed enclosure. Here are a few other sites to check out (I'd go more in-depth but I have to get to work).
      • keyser
          Originally posted by John D
          Anyone? :P
          Jon's tested the Aura 12" and it's one of the lowest distortion drivers he's ever tested. I'm not sure if the 15" has the same design.
          That said there's quite a bit of debate regarding the audibility of distortion at low frequencies.
          • John D
            • 26
            Mazeroth, I'd like to hear your more in-depth comments when you can find the time. Thanks so far.
            Thomas, would you point me to where I could read more about that test?
            In my experience, non-linear distortion is still very important in the bass range. Our hearing is less and less sensitive at lower frequencies. The harmonics will therefor always be in a range where our hearing is more sensitive than in the range of the original stimulus.
            I understand your point, though.
              • 1532
              The Aurasound 12, unlike most woofers/subwoofers, actually has falling levels of distortion with increasing frequency, which SHOULD be the case considering the reduction in cone travel for the same output level. For most subwoofers, this is not the case, and as a result they usually exhibit more high order HD and IM products in the audible range, as well as greater issues with integration.
              I'm sure there are lower cost 15" subwoofers with 25 mm Xmax. There may not be better or equal performing overall 15" subwoofers with 25 mm Xmax and clean performance to 500 Hz.
                All of Jon's tests are in the Testing 1,2,3 in the archived threads.
                OK, it's a goofy title, but perhaps meant to indicate the tentative nature of any conclusions one might draw- Got back to doing some driver testing this weekend. Eric Eva brought to my attention some test data published in Germany for a number of roughly 7" midbass drivers, including the Peerless 850439 and the 850467;
                • tyler
                  • Feb 2007
                  • 101
                  http://www.htguide.com/forum/showpos...&postcount=265
                  Those are very impressive results for a 12" woofer. :T
                  It appears that Aurasound only makes a 10" (NS10-513) that shares the same design as the 12" (NS12-513) that Jon tested.
                  From the specs it doesn't look like either would perform as well in the upper frequency range as the NS12-513.
                  The 15" (NS15-992) shares the design of the (NS12-794) 12"
                    • 5204
                    ET,
                    It is always said that adding a second woofer reduces the individual load on each, and therefore reduces the distortion. Is there anyway to look at the testing results and compare the distortion levels of 2 inexpensive woofer to 1 of a more expensive woofer?
                    • thadman
                      • Jan 2007
                      • 248
                      I think it would be simpler to calculate the SPL required for 1 of the 2 cheaper drivers to achieve the SPL of the larger driver.
                      Example, lets say 100dB
                      20(10^(100/20))=2,000,000
                      2,000,000/2=1,000,000
                      20log(1,000,000/20)=93.98dB, ~94dB required per driver
                      You could then measure the more expensive driver at 100dB, and the cheaper driver at 94dB and compare. If you mounted them opposing (push-push, reduces even order distortion/vibration) it would be a different story however.
                      (sorry, didn't see that this thread was 7 months old)
