What Sub fits best?
  • Risingjay
    • Oct 2006
    • 16
    What Sub fits best?
    I'm in need of a sub and need advice.
    Here is what I am working with:
    Mains- Klipsch Chorus II's 101db @ 1w/1m, +-3db down to 38Hz
    Room - 14.5W x 18L ( Is this considered to be a small to medium room or just small?)
    Sub Amp- QSC 3402
    What I want to accomplish:
    1.) Tight bass (kick drums) for music
    2.) The deepest lows for movies
    3.) Looking at crossing over at 60Hz or 80Hz
    My Thoughts:
    1.) Sealed - Design a sub mimicking kramskoi 2x15" TC3000 .45Q sealed sub design but use 2x15" TC2000's. I figured the box or cylinder will have to around 14 cu.ft. in order to get the same performance as the 2 TC3000's. I'm O.K. with that.
    2.) Ported / LLT - Use the 320 Liter design that has been discussed and proven here with a TC2000.
    I would follow the advice here and get an EQ to dial in the sub.
    Which design do you think would best fit my hopes and dreams of a sub that will fullfill my music (which I listen to a lot) and do the same with movies (which I watch a lot of)?
    I enjoy reading all of the projects posted here. You all have inpired me to go the DIY route. Thank you.
    • 10931
    I find the 3000 a bit perplexing. The Le is extremely high, this and other aspects of it makes me think it's better suited for car applications. (yes I know all about Kramskoi's designs)
    The price premium for the 2000 over the Soundsplinter RL-p15", means I recommend the RL-p15"
    The choice of sealed or ported is simply a function of whether you want to live with a monster sized enclosure, or use power and EQ with a smallish box.
      • 5202
      I think the difference between sealed or ported comes down to size versus $$$. (Pretty much the same as what Thomas said)
      If you have the budget for 2 TC3000, go for 4 sealed RL-p15.
      • kgveteran
        • 865
        I dig the small sealed with loads of power and proper LT. Unless IB is in the air........is IB even a thought ?
        • Risingjay
          • Oct 2006
          • 16
          I wish IB was an option! I would make life a lot easier. I would like to know which style sub would go best diven the size of my room. Again, I don't mind the size of the ported. I just want the music to sound as good at HT. Tight, real and go infrasonic when called upon. IB would do it but not an option. If I attempted IB, It would have to be located in back of the listening position and from what I have read is bad.
          As far as budget, I can afford 2 TC2000's or 2 RL-P's, not 2 TC3000's.
          As far as parametric EQ's, can you increase gain under 20Hz, and also are there lowpass filters on them?
          I'm still kind of new to this.
          • mmoeller
            • 138
            Someone finally said this. I modeled the 3000, and it seemed to have a very narrow response. Almost like a high Q car sub.
              • 10931
              I think a pair of RL-p15"s is one of the best deals around for high performance.
              Unless you buy a Rane PE17 you won't find an parametric equalizer that boosts below 20Hz. The Rane has a 10Hz hinge point.
              You only need a high pass if you go ported. The current devices don't offer this option. Chasw98 and I have been developing an add-on box with several interesting functions including a selectable high-pass. More information will be posted as the project evolves.
