Question before I cut sub legs
  • jacket_fan
    • Oct 2006
    • 83
    I am building the cabinets for 15 inch drivers. These are downfiring and will sit on carpet. They are sealed.
    Before I cut the legs, is there a definitive minimum distance above carpet the driver should be?
    I had previously had 3 inch legs made out of left over MDF and it seemed OK. The finished cabinets will have cherry legs and before I cut I would like to make sure I am not too short.
    Mark
  • Gir
    • 309
    I believe the normal range is between 4 and 5 inches, but I couldn't tell you a "set" value you should use.
    -Tyler
    • jacket_fan
      • Oct 2006
      • 83
      Is there any difference between carpet and hardwoods. Or for that matter, on a concrete slab versus a trussed floor?
      Mark
      • gmed
        • 207
        As a general rule, the distence from the ground should be the same as from the lip of the sub to the depth of the dust cap. usually 3".
          • 10931
          The floor construction isn't important.
          With carpet the legs sink in so they should be a bit longer than those for wood or tile floor.
          The absolute minimum for no resistive loading would be enough height to create a space equal to the drivers Vd.
          Most people simply use ~3"-4".
          Designs like those from SVS use a shorter length and a floor plate. This is intended to resistively load the driver, that increases output slightly
          • jacket_fan
            • Oct 2006
            • 83
            I am no expert on T/S parameters, but Vd is a cubic measurement. If the height is one parameter, what would the other two be?
            In winISD I get the Vd to be 148.2 cubic inches for a Tumult.
            I really am not sure where to go with this...
            The plan is to have 2 1/2 in wide legs and if they get longer than 3 inches below the bottom of the box, I think they will look to "dainty".
            Mark
            • Inu_Yasha
              • 256
              3" won't look too dainty, if I have time today I'll take a pic of my downfiring sub that has 3" and it looks great IMO with 3".
              • jacket_fan
                • Oct 2006
                • 83
                Thanks...
                Mark
                  • 10931
                  If it's a tubesub it's the area created by the circumference of the tube, otherwise it's the dimensions that comprise the cross-section of the box, depth*width.
                  • jacket_fan
                    • Oct 2006
                    • 83
                    The cross section is 22*22. That equals 484 sq in. But that is greater than the Vd from unibox. Perhaps I input the wrong data into unibox and got the wrong Vd.
                    I attached a pic to show the status of the two boxes.
                    Mark
                    • collo
                      • 67
                      The shaded area should be equal or greater than Vd.
                      In your case 22 * 4 * clearance >= Vd
                      Ports rule ...
                      • Brian Bunge
                        • Nov 2001
                        • 1389
                        I had a Tumult in an 18" cube with 22" long legs, which raised the bottom of the box 4" off the floor. It worked very well.
                        • jacket_fan
                          • Oct 2006
                          • 83
                          148.2/22*4=1.68
                          Looks like anything over 3 inches is acceptable.
                          Just trying to follow the rule of thumb of measure twice, cut once.
                          Thanks for the input guys.
                          Brian, these will have a cherry veneer, with cherry trim. The veneer went on fairly well using contact cement and a j-roller. I am having a devil of a time with the finish. I had used a method right out of Fine Woodworking using sanding sealer/dye/washcoat/stain on some stands I made for aome Maggies, but this veneer is not taking the same process as well. Is there anything you do different for veneer as you do for 3/4 in hardwood? I was actually pleased with a wood working project for a change. The grain really had depth and is attractive.
                          Mark
