I'm baffled.
  • LNeilB
    • 32
    I'm baffled.
    Aw hell it's Friday, excuse the pun.
    I just got a pair of PE .5 cu ft cabinets. I don't know any local woodworkers.
    Is there anyone who I might mail the baffles to in order to have them cut for the Krutke L18?
    Name your price.
    Cheers,
    Neil
  • Biff
    • 61
    Try any local cabinet shops, or car audio installers. Either one should have a circle jig and router set and tag you for a couple bucks and on you go!
    • cotdt
      • 393
      it's very easy to do. you can learn it and it will pay off. the tools aren't too expensive, either.
      • LNeilB
        • 32
        Ok
        I'm all for that. What do I need to buy? I'll have to cut port holes in the cabinets as well.
        Cheers,
        Neil
        • jhd
          • 6
          Three things:
          1. A hand-held router (not a table-mounted router). For cutting holes, any router will do, but I would recommend a variable-speed router with a 1/2" shank. (Most inexpensive routers come with a 1/4" shank.)
          2. A straight router bit for cutting.
          3. A Jasper Circle Jig from Parts Express (or elsewhere?) to cut perfect circles.
          Routers are easy to use and really useful. Probably the #1 or #2 power tool for DIY speaker builders (before or after a table saw).
            If you're handy you can make a jig similar to jasper...
            And, get a plunge router not a fixed base router.
            Also, for driver cutouts 1/4" is probably fine as most of us use 1/4" diameter bits for that... I like spiral upcut though for a finished surface I'll do the first pass 1/16" deep cut with a spiral downcut.
            • LNeilB
              • 32
              der
              Just realized a friend does cabinetmaking. Heading over tomorrow to have him zip through it. :T
