my LLT subs for a the theater
  • indygreg
    • 35
    i posted this on another forum but thought it might be of interest here. i have seen this called an LLT (large low tuned) sub. i am using the tc2000 15" drivers.
    the only thing better than an LLT is 2 LLT's so i built 2 97" x 36" x 18" boxes using about 700lbs of mdf. inside each one i used braces every 15 inches. many speaker builders use a solid piece of mdf and cut circles out but the idea of cutting 24 circles with a jig saw was not fun so i cut pieces on my tablesaw to the exact dimensions and put them together like this
    i assembled them into the boxes like this
    each box was has a port tuned using the unibox software to 15 hz.
    here is the finished product stuffed with insulation
    i had a day in building the speakers but i saved the effort of filling the stage with sand. we will build the stage in front of the subs and they will stay planted firmly on the concrete behind the stage and screen wall.
    i had to laugh when it occured to me that early on i debated putting the sub in the center or in a corner. with this 16' long wall of sub i have both
    i ordered a crown k2 today to drive this thing. i plan to listen to it with the port open and also with it sealed over to decide what i like.
    greg
  • Ecir38
    • Oct 2006
    • 130
    That's pretty sick you need to post this here too.
    BR
    • PoorboyMike
      • 637
      Wow, that is huge! 8O
      I'm not really sure I understand what you are going to do though. You said you only have 2 drivers but there are 4 holes in the front. Or are those the port openings?
      • indygreg
        • 35
        i am on avs all the time but did not know about that forum. i posted it there as you suggested. thanks.
        greg
        • indygreg
          • 35
          mike - i don't think i said i had 2 drivers. maybe you saw that on the graph which is for 1 of the two boxes. i considered just starting with one per box and sealing over the other hole.
          greg
          • PMazz
            • May 2001
            • 861
            I'm with you! I call them ladder style braces. Much better yield from a sheet, less work and just as strong IMO.
            Pete
            Birth of a Media Center
