What do you use to measure below 20hz?
  • warnerwh
    • 261
    It dawned on me nothing I have will measure below 20hz. I have a DEQ 2496 and a Rives cd but I don't think they go lower than 20hz.
    • 10931
    Room EQ Wizard will measure down to 10Hz.
    Note: see post #7 for a link to download the newest version of Room EQ Wizard
    If you don't want to join a forum to get a copy you can instead download it here http://www.f-forge.com/?d=9hD0Mi4VByYRza3udlg6
    It requires the Java Runtime Program, you can download that here. Install this before installing Room EQ Wizard http://www.java.com/en/download/manual.jsp
    TrueRTA will measure to 10Hz
    TrueRTA real time audio spectrum analyzer for PC's running Windows.
    • warnerwh
      • 261
      Thank you!
      • capslock
        • 410
        The question should rather be, what microphone measures reliably down to 10 Hz. A defined small leak is need to accomodate changes in barometric pressure, but if it is too big, a LF response drop will result.
        Having looked at Electret caspules from Panasonic and other manufactures, I wonder how defined the leaky seal is.
        • capslock
          • 410
          But why would you want to measure 10 Hz anyway? The only application I can think of would be microphonic feedback, where you need a sensor cutoff below the passband to avoid phase issues.
          • Xmax BR
            • 43
            Dears,
            REW Version 4.0 Now Available for Download...
            Tks,
            Renato
              • 10931
              One can directly download the zippped version of REW 4.0 Gold here
              http://www.f-forge.com?d=zVGa5u4cSHlL8jQAxWbD
              And one can directly download the exe file version here
              http://www.f-forge.com?d=Ao5ycn03buSqpxQ9vDae
                • 5568
                10Hz measurement is useful when trying to make sure you have accurate response that low.
                I have recordings done on an organ with a 64' (8Hz) pedal.
                • JonP
                  • 690
                  Hmmm... the first link for the zip file has gone extinct.. the second works but you need a password to start the download.
                  The earlier version worked (a few days ago)
                  • TacoD
                    • 1078
                    Indeed, I think the mic will be highly unreliable, also the amount of datapoints in the <20 Hz region will be small for the typical acquisition soft/hardware.
