I saw in another thread that people are considering phenolic as a baffle material. I'm curious what makes phenolic attractive for this application?
I am not a materials engineer, but I thought the advantage of MDF was that it had a moderate modulus of elasticity and a relatively high density, both factors combining to make it well damped. The MOE of phenolic is about 4 times that of MDF, and its density is about 2-2.5 times that of MDF. It seems to me that based on those numbers, phenolic would be less well damped and more prone to ringing, with the fundamental higher in frequency. In any case though, it seems to me that using two sheets of baltic birch plywood laminated together gives you roughly the same MOE as phenolic and roughly the same weight, but with the advantage of being much easier to source. For an open baffle speaker, surely the extra thickness wouldn't make a difference?
