For those of you that need a push to try wave-guides…..
For reference, in the past two years I’ve had active and active/passive systems configured in WWMTM, WWMT, WMTM, WMT and had them in ported, sealed, and in dipole configurations. Also had some ported line arrays….
Drivers used included Peerless 12” XLS, Eminence Kappa Pro 15lf-2, Seas W22, W18ex, SS18W/8540, 15M, PHL 1340, 1120, SS9900, Seas Millennium, Morel 110, North D28, G2, Newform 45” Ribbons, OW1, and a few I’ve probably forgotten.
Last summer I got a pair of BMS-4540ND compression tweeters with DDS I-90 Pro wave-guides. Also picked up a pair of 10” PHL extended midrange drivers.
I intended to set them up with the 15” bass drivers using a DEQX crossover, but being a compression tweeter and 10” mid, I had big time second doubts. Anyway, got them setup in temporary boxes and listened for a while. This was enough to convince me that I really should be getting some better boxes built…
The system came apart.…
….and for the last couple months, I rolled through all my “normal” configurations :Z while figuring the box thing out for the pro drivers ;x(
Yesterday, got the new boxes stuffed with the BMS and PHL drivers and spent a few hours on the crossover. Points ended up at 200hz and 1600hz. Slopes are 96db per octave.
I suppose the most controversial component in the speakers are the compression tweeters and wave guides.
So, how do they compare to the other tweeters mentioned?
There simply is no realistic comparison. The BMS not only has an order of magnitude more headroom, but it just plain sounds a lot more real. Cymbals, Triangles and instruments with a lot of air and shimmer are the best I’ve heard. Fantastic definition. They also excel with complex sounds such as brass and large orchestras.
The 10” midrange? Again, like the BMS, it just feels unlimited in headroom and never sounds strained. Female vocals never sound thin and male vocals project with great weight.
Anyway, for those of you that are tempted to try a wave-guide: I’d say go for it. The more even dispersion and extra headroom they provide at the bottom end do pay off.
For those of you thinking of trying a compression tweeter, some of them are pretty nasty, but I’d take a BMS with Digital EQ over any ribbon or 1” dome I’ve ever heard. 8)
If there is one thing this system has enforced in me, it’s that the more I think I know, the smaller and less interesting my world becomes.
B
Heres a photo of one of the speakers. Just need to round the edges and paint them.... :B
B
