It was suggested to me to have a template of the driver layout to overlay and use to cut out the holes for the drivers. Using the 10mm veneer and the pva glue method.
I do not have any experiance with routers, but would have thought that is what most use, or very carefully go slow with a sharp trim knife?
Or do you use a template overlay?
Thanks for helping a newbee.
