Question about coils
  • Jonasz
    • 852
    I have a 0.5mH coil and I need to unwind it to 0.44. How many rounds do I need to unwind to get the right value?
    turns1/turns2 = squareroot(L1/L2)
    • Jonasz
      • 852
      Thanks a lot Dennis!
      • engr_dave
        • 112
        That formula only works when you know the number of turns in the original coil. And it is not 100% accurate. Dimensions DO make a difference:
        If we let S1 = (c/2a)2 then the inductance, in henrys, can be approximated by
        L = 4×10-7[pi]a N^2((0.5+S1/12)ln(8/S1) -0.84834+0.2041S1)
        where a is the mean radius of the winding in metres.
        Example: If the mean radius is 2.4 cm, the width is 9mm and N is 350 then L = 6.977 mH
        Clearly, the easiest way to do this is to buy a cheap multimeter that measures inductance like this one
        and just unwind until you measure the right value.
        Dave
