Question about Modeling RL-P15
  • dsl1
    • 33
    For Christmas I received a Soundsplinter RL-p15 sub and am looking forward to building a sonosub.
    I went ahead and purchased a 4.5ft length of 24in sonotube for 40$ from the local concrete place. Unfortunately, I now realize if I go with the classic 260-265L enclosure with a ~25inch length 6inch diameter port the driver would be touching the end of the port.
    I posted on avsforum and was told I could increase the enclosure size and should model it in winISD. I went ahead and put in the data for the duel 4ohm rl-p15 and this is what I came up with. The lumps look kinda weird to me but I am not sure what the ideal look should be. Any help would greatly be appreciated.
    350 Liter's at 18hz. I would be fine with this size as the port wouldn't even be close to the driver anymore.
    Image not available​
    For reference here is the 265L model. Hopefully will show if my driver numbers are weird if this one looks off.
    Thanks in advance :T
    Last edited by theSven; 03 July 2023, 21:56 Monday. Reason: Remove broken image links
    The plots you see are anechoic simulations, not what the sub will do in a real room. In a real room the lower frequencies are filled in by room gain. So the dip (saddle) in the 350L plot is filled in when the sub is operated in a room.
    • dsl1
      • 33
      Okay great. So 350L should be fine? If I tune it lower in winISD it drops off at a much sharper rate. Is it possible for you to say how much lower I could tune it and have room gain balance it out? 14ft wide 8ft high 22ft long carpeted basement with drywall.
      I would like to to go as low as possibly smoothly, but am not sure where that point is. I can go 350-375L no problem.
      Thanks in advance. I'm off to Menards to grab MDF, pipe, black paint, etc... :T
      • dsl1
        • 33
        Got everything except the bolts for the driver. Can't seem to find any button head ones that are 4inches long Will figure that out tomorrow. Any idea what I could get?
        Any ideas on what volume it should be and what I should tune it to?
          I just use drywall screws to hold my RL-P15 in place. I've done the t-nut thing, and broke a few loose. Lots of people here just say to use a drywall screw, so that is what i did and it is working fine.
          Several people have built RL-p15 sonosubs with 320L and somewhere around 15hz tune. That is Steve Callas's typical recommendation. Do a search for the exact numbers - shouldn't be hard to find one.
            The lower the Fb the greater the saddle. The greater the chance that room gain will not fill it in.
            Room gain depends not only on the geometry of the room but how 'lossy' (flexible) the room is. So rooms with lots of doors and standard drywall construction will have less room gain than a room with stiffer walls (like a basement) and fewer doors.
            The person primarily responsible for starting the trend of people using the RL-p15" for home subs is posting in this thread. As a result I don't think the OP needs to look elsewhere for guidance.....
            The OP's limiting factor for how low he can tune, with be the length of his tube in relation to the length of the port.
              Yep, you are correct. I just couldn't remember offhand you giving adivce on one this big. I saw the 350L, and it seemed like there have been a few recently that he could copy. I must have missed how he is going to have trouble fitting the port in. 15hz is around 39" long, so I would think that would just fit in a 4.5' long tube. I must be missing something, so I'll hang up now and listen to your comments.
              • mackintire
                Does winISD have issues modeling Passive radiators
                by mackintire
                I was investigating the idea of using 2x Dayton RSS390HF-4 in a balanced opposed location in a 6.5 cf box with a single 15' passive radiator.
                One driver on the left side, the second on the right side with the radiator firing towards the audience.
                I was considering one of...
                16 November 2010, 16:23 Tuesday
              • GSM
                Need confirmation and modeling help - noob DIY sub
                by GSM
                Ok, been a lurker around the boards for years. 5 years ago I was just about to pull the trigger on dual tempest (sbb4 design) but a few things came up (another kid, new house, etc....) I ended up getting a SVS pcplus 20-39. Love the thing and even upgraded the driver within the last 6 months. Old driver...
                21 February 2008, 16:04 Thursday
              • Efalegalo
                Port Related Issue: Thoughts on how I can resolve?
                by Efalegalo
                I'm building an MTM with a slot port up on the front bottom of the enclosure. The port was made large enough so I wouldn't run into port-noise issue.
                After taking far-field measurements, I observed the response of the woofers was a little more ragged than I had hoped.
                Then...
                17 November 2019, 13:34 Sunday
              • Mike82
                A few questions about using WinISD?
                by Mike82
                I am trying to design a vented box for a DIYMA 12" sub using WinISD. I read threw the tutorial on HTS which helped out alot. I have few questions that it did not cover though. I am trying to tune it at 30Hz and it seems to want 30L for volume. Which is really small, evidently these subs like small...
                22 May 2009, 19:13 Friday
              • Villainstone
                Simple WinISD question
                by Villainstone
                Hi guys I have a simple question about the ports in WinISD.
                When I use multiple ports as opposed to just one obviously the program changes the port length. Now the new length that it tells me is that for each port of should I divide that new number in half for the length of each port? TYVM f...
                08 October 2011, 17:36 Saturday
