subwoofer question
  • jp88
    • 8
    subwoofer question
    I am currently trying to decide what I will do about a new subwoofer. I currently have a set of dayton budget home theater speakers I built using the classic 5.25 and the classic aluminum domes and I have a chincy sony 50 watt powered sub(if you want to call it a sub). I have a small room about 12 x 14 with a vaulted ceiling and I have some size limitations. I was thinking about a starting with a dayton rs 12 HO in a small sealed enclosure with a ep1500 and a bfd used as a lt circuit eventualy building a second rs12. and a second ep1500 if needed. I will also be building some modulas and modula mts to replace my budget daytons eventualy. My main questions are will 1 rs12 be enough. and how small can I get away with making it. I am also open to sugestions of other ideas but remeber Size limitations and no IB.
    I hope I didn't ramble on to much
    You haven't posted what the box size limitations are....
    • jp88
      • 8
      Id like to try to keep it around an 14 inch cube.
        That's way too small for a 12" unless all you want is BOOM.
        • WillyD
          • 675
          The 12" dB-500 from TC looks ok in a small cube.
          • jp88
            • 8
            how would this tc sounds db-500 12 be in 1.5 cubic feet sealed with a lt circuit.
              The BFD can not be used to create an LT circuit. The DEQ2496 will create an LT.
              If the budget permits the SoundSplinter RL-p12 would be a better choice in this application
              • jp88
                • 8
                I can't run this through winisd right now because im at the inlaws house. would the db-500 12 be a good option in a 17 inch cube (2cf) with a 500 watt plate amp, and lt
