modding Rythmik Audio A350 plate amp to disable crossover
  • mazurek
    • 204
    Originally posted by warnerwh
    I have the Rythmik 350SE plate amp and would like to know how to disable the crossover in it. I'm not very knowledgeable with electronics but if it's easy I'll do it. I will be buying an outboard crossover so I can run both of my subs with it instead. Same with the volume, could I just connect the two wires going to it or is there more to it than that?
    Thank You
    Here's a pic showing how I mod'ed the Rythmik audio plate amp to remove its crossover. I'm not sure where the volume control part is, I modified it to connect the input directly to the amp module. As shown, input impedence is ~ 28KOhm, and gain is somewhere from 33-35 dB. I wouldn't do the mod if you are running real long cables, or if you have significant dc offset on your inputs. My voltmeter shows it still has some attenuation at real low frequencies, so it likely has capacitor coupling on the amp board, I just never traced it out.
    Don't go eating my bandwidth if you are not actually interested in any way,
    I didn't want to raise my old thread, I think the moral of that one is that next time I should try trading amps or something with someone here that can build me incredible cabinets.
  • Mazeroth
    • 422
    Way to go, Lee! :T
