I've been working on a loudspeaker project forever now, and I shelled out a good bit of money to get some cabinets built (I live in a condo, and electronics are my main game right now).
I asked for void free baltic birch, and the builder gave me a quote that said they will be made from russian birch. Anyway, two-three months later, I finally took delivery of the cabinets, and they have all sorts of voids. Of course I don't know what expect, so could you please assess the quality of what I got, I have some pictures attached. Some internal parts look a little flimsy with voids, they did a good job of hiding them on the outside.
Also he laminated 1/4" and 3/4" plywood to make my 1" thick baffle, but clamped them together with many staples all throughout. I thought that was a little stupid seeing as how I told him I would have to route holes. I'm confident a carbide bit can work through that, but it seems a like a bad idea to plow through staples. Not sure though.
He gave me one warped baffle that he said he would replace, so I used that to cut some test holes. I was planning on using socket head screws, and got a counter-sink bit from mcmaster. Some of the holes ended up well, but some ended up with the socket screw pulling through when I tightened them. Is high quality plywood supposed to be that weak? I figure I will try and use some wood hardener in the next baffles.
So what would your advice be, and how should I salvage these cabinets. Are they that bad? I don't really have money to redo. My plan right now is to brace them a whole lot, and use wood hardener for all screw holes.
