FINISHED - Pic of my new TL subwoofer :)
  • Xmax BR
    • 43
    Dears,
    In this week, I finished to my friend a BIG Subwoofers in Transmission
    Line configuration... wiht only 2 x 12" (FS 22hz, XMAX 13mm)
    The bass is the best I hear, big resolutin, fast with perfect
    transient. For music, nothing is better... IMHO
    The problem is the size (160cm x 70cm x 40cm) and your weigh, 150kg.
    Ps. I read english without problem, but write with all problems... :rofl: :rofl:
    Tks,
    Renato
  • Paul H
    • 904
    Nice work :T
      • 10934
      Good job.... :B
      How did you stuff the line?
        • 15284
        Built a lot of TL's in the 70's Nice work- I'm sure you dont' want to move it around too much!
        Any response plots?
        • Inu_Yasha
          • 256
          Xmax BR your work always looks so beautiful. What line of work do you do?
          • warnerwh
            • 261
            That's beautiful, nice job!
            • technimac
              • 233
              :agree:
              Renato,
              Very, very nice finish and construction quality.
              I hope they serve you well.
              Cheers, Bruce
              "While we're at it" - the four most dangerous words in Home Improvement
                • 3791
                Renato, it's not clear to me on this pic where the drivers and the port are. In the baffle that's already glued on or in the one that hasn't been mounted yet? Is this a true TL with the drivers at one end of the line and the port at the other end? Or is it more of a tapered quarter wave pipe thing with the drivers mounted in the middle of the pipe?
                • mrogowski
                  • 55
                  That is nice. I too am curious what stuffing you used. I did some TL's in the 80's and used long fibred wool. Not sure if its still in use..
                  Where no sound has gone before
                  • Xmax BR
                    • 43
                    Dears,
                    Thanks for all nice words ! This is a classic open TL, based on 25hz,
                    1/4 wave - (344/25)/4 = 3,44m - start with 1,5 and finished with 1 SD
                    In Brazil do not have "long fibred wool", then, after long find and
                    tests, I use "plumante", is cheaper and very good. See pic:
                    I put inside of "acrilon" bags:
                    Dennis,
                    The "port area" is in the end of line, see:
                    Tks,
                    Renato
                    • Xmax BR
                      • 43
                      This "near field" (2,5cm) of only one driver:
                      This "near field" (2,5cm) of "port area":
                      I use REW and Radio Shack dcbl
                      Tks,
                      Renato
                        • 3791
                        Thanks Renato, I see how it works now. Two of the braces have cutouts for the drivers.
                        • Xmax BR
                          • 43
                          Dears,
                          More pics:
                          Tks,
                          Renato
