Greetings: I've been directed to this forum as I understand there are world class sub builders here.
I just ordered the Dayton RS Hifi 15" woofer. I'm planning on using a sealed box 2' square. This will be heavily braced as well as using some granite I have inside. Then I will fill it with fiberglass.
It will be powered by a spare channel of a Cinenova 3 power amp I'm using in a biamp configuration.
This is the most important consideration: I want the fastest most accurate sound I can get from this driver. I learned of this driver from the people at the Partsexpress board. I'd been willing to spend more and had been apprehensive about buying a Dayton brand driver but have been assured this is an excellent driver.
I want a sealed box as I want the tightest bass possible. An excellent transient response is necessary due to the fact my main speakers are hybrids with planars for mids and a ribbon tweeter. They're VMPS RM 40's.
This sub will only be used for music so the lowest lows aren't necessary. I do want however excellence to 25hz and have been assured with this driver I can do it.
If you see any way to improve what I've got in mind I'd appreciate the advice as I've never done this.
Thank You
Thank You
