cant find them anymore
does anyone have the t/s for ascendant avalanch 15"
Well that's gonna open a whole can of worms, but a LLT is always worth it in my opinion. You have to determine what your needs are though - if you'd prefer a smaller sub and don't need big output down to the low teens, then sealed would suffice.- Bottom
I had copied the parameters from the site a while back so here they are:
Avalanche 15 T/S Specs
Fs 15.7 Hz
Qms 3.5
Qes .334
Qts .305
Vas 300.6 L
Re 3.2 ohms
Znom* 4 ohms
Xmax 27 mm
Sd 749 cm2
Mms 269 g
Vd 4.04 L
Pnom 800 watts
Le 2.4 mH
Cutout 14.125"
Diameter 15.5"
Depth 7.875"
Weight 37 pounds
Hope this helps.
Regards
ArvinK,- Bottom
