I dont have any programs or knowledge on how to use them...
but I built a box for it, based on info givin from another site, and it sounds ok...
But I am open to other sugestions...
Spec are a s follows:
Ma Audio Sub Ma10d6 (dual voice coils, 6.ohms)
FO: 29.58
QMS: 3.48
Qes: 0.47
Qts: 0.41
Vas(L): 43.97
Revc(OHm): 2.7
Spl@ 1wat/1Meter(db): 85.66
Xmax Linear PK-Pk(mm): 20
Levc @ 1k Hz(mh): 1.4
Enclosure Volumes - Sealed:
Sealed(cu.ft.): 0.5
Fill Required (%): No
3db Down point(-3db hz): 51
Maximum Sealed(cu.ft.): .75
3db Down point(-3db hz): 50
ENCLOSURE VOLUMES - Ported:
Vented (Cu. Ft): 2
Vented to (Hz): 34
3dB down point (-3dB Hz): 29
Port Diameter ("): 3
Port Length ("): 15.5
Number of Ports: 2
thanx for your help, sugestions...
chris
FO: 29.58
QMS: 3.48
Qes: 0.47
Qts: 0.41
Vas(L): 43.97
Revc(OHm): 2.7
Sealed(cu.ft.): 0.5
Vented (Cu. Ft): 2
Vented to (Hz): 34
Number of Ports: 2
chris
