Hi folks, I have been lurking here for a couple months and have learned quite a bit from you all. Thanks! Hope I can contribute to the "collective" as time goes on.
Here are a few "before" pictures:
Images not available
So here's the challenge: my 2 ch setup is in a large room above the garages. I added a large dormer in there many years ago, and framed in soffits on either side for decoration. I have some improvised subs in these soffits & it sounds better there than most other locations in the room. AND, they are situated directly behind the main speakers from the listening position. So I think that if the entire soffit on each side was converted into a sub box, a really first class setup could be realized. I'm going to start gutting them out and building in double-layered and braced boxes within the resulting spaces. I'm thinking of making the front opening about 32"w X 38"h. That way I can have the flexibility to substitute different front baffles and drivers. This size could accomodate up to: (2) 18", or (4) 12", or (4) 15" drivers on each side...could make for some fun experimenting in the future. I could even build the opening so that a vertical internal baffle could divide the cabinet into two cavities with different volumes. That way a couple 12s could be augmented by an 18. (of course that would mean another crossover).
So the possibilities are exciting (well, maybe I'm wierd that way). I looked through the Parts Express, Madisound, and Zalytron catalogs; plus all the sub drivers mentioned on this forum (adire, sonic craft, adire, TC sounds, etc.)
OMG, there are millions!
So, to the point: What would YOU do?
Goals: (in order of priority, based on my limited knowledge)
1) Musicality...this setup will be strictly for 2 channel music.
2) Highest sound quality/low distortion.
3) Able to convey even subtle low freq info (such as an ever-so-lightly touched kickdrum in the background of a piece where you "sense" it more than actually hearing it).
4) Flexibility to use with standard 2way monitors, or with high efficiency monitors for tube equipment, or with ribbons or electrostats in the future. (might not be possible; I don't know)
5) Super low frequencies are nice but not as important as all the above.
note: I don't mind spending extra on the drivers if it makes a difference since the cabinets will be totally cheap and I already have the electronic xover.
Stats:
-room volume about 3900 cu ft. (22'4"X23'2"X7'6"ave.)
-volume of proposed boxes about 40.8 cu ft(1150 l each) (21d"X60h"X56w")
-current equip:
Arcam CD33 cd player
DEQX PDC 2.6 preamp/active xover/para eq
Bel Canto eVo6 6 ch amp
North Creek Vision Monitors (SS D2905/9900 Revelator Tweets & SS 15S/8530K 5" Mids) originally designed to high pass at 85hz 3rd order.
Crown K2 amp standing by for this project.
sure appreciate your input,
hope this wasn't too long,
John
Stats:
-current equip:
John
