First, where I'm going.I'm looking for three surround speakers.I have room for 6.1 which I am using now.
My subs are (4)Adire Tumults sealed, powered by QSC 1450's bridged each.My mains are three RS centers all three stand horizontal.Soon to be powered by three Outlaw Audio M-200's each. I have done alot of research to get to this point.Mt front stage is very strong and clean and clear.It extends down to 10hz and up to well over 105db, to give me the headroom at normal 85-90db listening.Thanks to you guys.
I need three surrounds that won't give out under pressure.I want to build these once and be done...for a while.I XO @ 100hz. I was looking at the WT RS180/RS28a sealed . The tweeter is fine ,but the 180 I feel will breakup under high SPL's (Or not).I was also thinking the WTW RS150/RS28a/RS150 sealed.I built that one for my cabinet guy and he loves it.I need to round out this system just shy of three more RC Centers .
My one concern is the XO point for the rear surrounds.I would rather use 80hz due to the distance from front stage sub to rear speakers.The 100hz point for the mains is fine as the subs are upfront and center and blend quite well.
This project will take the remainder of the winter so I have time.Cabinets,XO's
and an amp to power them.I like the three channel B&K 1430.It's about 125 per channel.Your thoughts.
KG
KG
