Hi everyone. I need some advice. If I were to build a 3way MTMWW or MTMW what would be the tradeoffs of using 6.5" or 5.25" as the mid?
This speaker will be used for 2ch music and HT, sometimes at higher volumes, thus the multiple drivers. I've been reading some of Dr. Floyd O'tool's (sp?) findings concerning power response and it's effect on SQ, and some of the drawbacks concerning the MTM layout and it's off axis lobing around the wavelength between the mids' acoustic centers. Smooth power response and minimal cancellation between mids will be a design goal with these. Given that, I decided to use 5.25" for better HF off axis dispersion and the ability to have closer acoustical centers, minimizing off axis lobing.
So what am I losing by going this route? Low distortion even at higher volumes is important to me. Obviously the 6.5" would keep distortion lower at any given SPL. I assume power compression would be lessened at any given SPL with the larger woofer. So what else should I consider?
