I've been looking into starting on my Modula MT's soon, and I'd like to build the cabinets first. Does anyone have any examples of the stands they have built for speakers such as these? I saw a couple I was into on the Modula MT Mission Accomplished page, but I'd like to see more if anyone has any other examples. Thanks a lot!
Modula MT Stands?
Tags: None
This is what I'm going to use for my Nat P's.- Bottom
I was just going to say, build them as towers and just seal off the bottom section by placing a piece of MDF where the bottom of the monitor sized cabinet would go.- Bottom
I'm building stands for my Modula MT's as we speak. I'll try to get pics up this weekend. Basically just rounded over 3/4" MDF for the base and the top with a piece of 3" PVC pipe down the center. It will look nice all painted flat black and I can put sand or shot in the pipe for weight. I might even use a piece of threaded rod down the center of the pipe to keep everything together with the extra weight of the sand inside. Hope I explained it well enough, if not wait for the pics.- Bottom
Originally posted by BigJim_inFLAI'm building stands for my Modula MT's as we speak. I'll try to get pics up this weekend. Basically just rounded over 3/4" MDF for the base and the top with a piece of 3" PVC pipe down the center. It will look nice all painted flat black and I can put sand or shot in the pipe for weight. I might even use a piece of threaded rod down the center of the pipe to keep everything together with the extra weight of the sand inside. Hope I explained it well enough, if not wait for the pics.
Originally posted by Brian BungeI was just going to say, build them as towers and just seal off the bottom section by placing a piece of MDF where the bottom of the monitor sized cabinet would go.
I'll toss around the idea of towers a little more, but please, keep the ideas coming. If I were to build tower speakers, though, I would be very dissapointed if they didn't have the bass I'd expect from that size speaker. So, I can only assume the simple solution would be for someone to rework the crossovers for me to allow me the use of a nice 8" woofer in the bottom :T
Thanks for all the replies, guys!- Bottom
I am not Dawaro the muslim state in Ethiopia...Just DAvid WAyne ROberts- Bottom
Here's a pic of the stands I built. 3/4" MDF with a hollow center filled with lead shot. Spikes on the bottom. Clear, round cabinet bumpers on the top to sit between the stands and the speakers.
Two pieces of 3/4" make up the bottom plate.
Image not available- Bottom
Originally posted by RolexHere's a pic of the stands I built. 3/4" MDF with a hollow center filled with lead shot. Spikes on the bottom. Clear, round cabinet bumpers on the top to sit between the stands and the speakers.
I was gonna make some stands for my rear surrounds, and was all but ready to buy the wood, etc.......and then I saw these in person, and saw the price on PE:
free shipping too, and they are SOLID! just too easy honestly!- Bottom
Originally posted by Inu_YashaThat looks incredible! How much did to cost to make those? I'm seriously thinking about doing this for my Nat P's.
Right around 40 dollars for the set.- Bottom
Originally posted by RolexVERY cheap to make. I think 19 bucks for the 4x8 sheet of mdf. Then I used a quart of primer and a quart of paint. I already had the lead shot. I got the spikes free from my local B&W dealer.
Soil would be okay. But.......soil contains moisture, and moisture destroys mdf. So...if you are going that route, make sure you have almost zero moisture, or...put the soil in some type of sealed bag (plastic) before it goes into the stand.
I think I made that stand with a 4"x4" inside dimension for the column which gives a 5 1/2" outside dimension for the column. I added the second base after I decided the first wasn't big enough to be stable.
It's all coming back to me now. The first base was a 10"x10" the second base was a 12"x12" base. I only chamfered the top edge of the smaller base and was very happy with the way it turned out..- Bottom
Great looking stands, guys! I'm liking all of these ideas a lot. Quick question, though; I saw some stands on the internet awhile ago, I believe it was on this forum, that looked very interesting and I've been trying to find a picture of it. They're kind of hard to explain, and I don't remember exactly what they looked like, but somehow the base "pole" was supported by a base of like three layers of glass sheet at the bottom. I thought it was pretty sleek looking, but I'd like to see it again if someone has a picture of it. Those of you who saw it hopefully remember what I'm talking about, but I'm sorry for the crappy explanation. I'm enjoying all of these ideas, though, so keep them coming!- Bottom
Originally posted by RolexSoil would be okay. But.......soil contains moisture, and moisture destroys mdf. So...if you are going that route, make sure you have almost zero moisture, or...put the soil in some type of sealed bag (plastic) before it goes into the stand.
Another way to help would be to seal the MDF by painting with lots of shellac or other sealer. Get some, water it down with alcohol to a "1lb cut" and paint it on till it won't drink anymore, a few times. Should be a good "moisture barrier" and help prevent swelling or molding.- Bottom
Jon is correct. But, this could be tough to do if you have already attached the column to the base. If you haven't, then using this approach won't seal the joint where the column is connected to the base.
If you can afford it, stay away from all that stuff and go with lead or steel shot. More dense than most any dirt or sand you can find, and doesn't have any moisture to ruin the stands.- Bottom
For what it's worth...
I recommend avoiding lead shot. It's toxic and will get in the air more than you'd think. It's metal, but a very low boiling point metal.
Dampening with playground sand is a good way to go. It's clean, dry, something like $3 for a 25 (or 50?) pound bag and, in the end, will provide plenty of dampening for this application.
I made the stands below for my Modula MT's. They ain't pretty, but this was just something temporary to be able to play my newly built speakers. Maybe $20 worth of scrap wood- 2x6 and 3/4" ply. About 2 hours worth of work to build 3, including cutting the wood, measuring things, screwing together, etc. I'll make something more serious out of solid maple and cherry soon. But until then...
Images not available- Bottom
Jon, you are correct, lead shot isn't the most child friendly. That's why I also mentioned steel shot.
Sand is okay, as long as it's dry. The last bag of sand I bought from Home Depot was soaked with moisture.
Looks like we each have our own preference.- Bottom
