OK, my lack of knowledge of electronics is now staring me in the face. I made 3 crossovers for the Modula MT’s. Checked them with a volt meter. Two of them come out the same and the third looks different. I would appreciate any help in figuring out what is going wrong.
The details: The two ”good” crossovers measure 6.9 ohms, the “bad” one is 7.0. I played test tones through the crossovers and measured voltage at the woofer and the tweeter. (Putting the meter leads on the woofer or tweeter leads.) In all 3 crossovers, the woofer response at a given frequency was about the same. But for the tweeter, the “bad” crossover is reading about 20% low. I put a table below of typical values. (Sorry, I can't get the spacing to make it look easier to read.) Just one set of values for the woofer because they’re all about the same. And a typical “good” and “bad” set of values for the tweeters.
Any idea what’s wrong? I tested each solder joint with the meter and they all look OK. I double checked all the components. They look to be correct as far as which piece is where. I switched around the tweeters and woofers. And, basically, I have no idea what to do now. Pathetic, eh? Thanks in advance.
-Jon
frequency woofer “good” “bad”
(Hz) tweeter tweeter
200 .035 0 0
500 .026 0 0
800 .024 .001 .001
1200 .019 .003 .002
1500 .016 .005 .004
1800 .013 .007 .006
2000 .011 .009 .007
2400 .008 .010 .008
2700 .007 .011 .008
3000 .005 .011 .009
3500 .003 .010 .008
-Jon
200 .035 0 0
500 .026 0 0
800 .024 .001 .001
1200 .019 .003 .002
1500 .016 .005 .004
1800 .013 .007 .006
2000 .011 .009 .007
2400 .008 .010 .008
2700 .007 .011 .008
3000 .005 .011 .009
3500 .003 .010 .008
