Are there any companies out there besides Pioneer that able you to connect your PC to your reciever to play music?????
pioneer recievers
Any PC with a soundcard can be connected to any receiver, via the soundcard output and a line level input on the receiver.
I prefer to buy a cheap coax cable with F->RCA adapters on the end, and go from S/PDIF out on the soundcard to the digital coax in on the receiver. Lots easier (unless you are doing multichannel out without that DD Mastering Studio or multichannel game audio thing).- Patrick
"But it's more fun when it doesn't make sense!"- Bottom
An advantage of using the SPDIF connection is that the receiver's SPDIF connection is frequently isolated, preventing ground loops. My Dell laptop cannot be connected to any unisolated input without causing lots of hum unless it is on battery power.- Bottom
I think what's confusing you is Pioneer's advertising of WMA9 Pro playback...it's a surround format from Microsoft.
BTW Do you plan on using a PC or a laptop to play your music?
It's often best to let the soundcard pass the digital data to your receiver and let it do the coverting to analog. This is because hopefully, your receiver has better components that accomplish the conversion.
You probably know your speakers must see an analog signal...CDs and ripped music is digital info to be read and converted to analog, somewhere somehow.
I use an inexpensive USB external soundcard on a laptop (but could use it on anything with a USB port), it's an M-Audio Transit...connected to the receiver with an optical cable...the receiver's onboard DAC (digital analog converter) will convert the digital information (to analog) with better quality than if I let the soundcard do the conversion.
Your receiver should have digital inputs of some sort to use its onboard DAC.
- Hope that helps....Randy- Bottom
