I’ve got to place my rear speakers nearly right up against a wall. These will be Modula MT’s used for rear speakers in a 5.1 system, with a sub. Perhaps I should plug the ports. This compromise doesn’t really bother me because it’s just for rear speakers- it’s not the main speakers for music. And I wanted to build ported speakers in case I like them enough to use as mains sometime down the road. And also for the challenge of incorporating the port into the cabinet design.
What do you use for plugs? Just some rolled up cloth (“put a sock in it”)? An option in my particular case is also to put a thin board or something between the rear baffle and the inside port, as shown below in the photo below. (That’s my first attempt at making a cabinet. The second and third ones look a little better.)
In general, what are the disadvantages of plugging the ports? (Other than reduced bass extension) Say, versus just making a sealed cabinet?
Thanks.
Thanks.
