PE seems to have the 4ohm version of the RS125 out. Specs say 4mm Xmax, 91dB SPL. Very welcome changes from the 8ohm version if they are accurate. The efficiency sounds hard to believe, maybe someone already has these and could confirm?
I did run a few models in WinISD and a 5 liter enclosure with 50Hz tuning gives a quite nice responce, 50Hz -3dB.
Any comments about using these as midwoofers in a 2-way?
