Alright, this thread is going to start out as a way for me to try and ask some questions and then (around Thanksgiving) start holding pictures of the build process for the room.
Back story:
My uncle wants a multi-use home theater area. He has purchased a Mitsubishi projector and is working on details for the room. It will be in a basement and used for HT purposes as well as general get togethers; my large family loves Ohio State football and will definitely be watching a lot of games in this room. It is a good sized room; not sure of exact measurements but I'd guess 20'w x 40'd x 9' h with an opening to the rest of the basement for the back ~15' of the left wall. Buying speakers to fill a room like this seems expensive. Here is where this forum and thread come in.
Value (budget) is a definite consideration for this setup. Thusly, I have helped my uncle choose DIY speakers to try and fill this room. We are planning on using the RS 3 way towers, WMTW center, and Modula MT speakers for a 5.1 setup (may be bumped to 7.1). The Seas tweeters will be used all around. Any initial thoughts on these speakers in this type/size of room? Obviously vocals are key in such space & for football viewing. We have not discussed sub options yet. An AV receiver will be used but amps for the mains & center are defnitey possiblities.
Some concerns crossed my mind since the speakers will be placed nearish walls, but with the depth of the front shelf, I don't think it will pose too much of a problem. The Modula surrounds will have to be very near wall, but the depth of those might make them acceptable there. I'm not sure if we can wait to hope for a non-BSC version--we will likely buy components next week if PE has a sale for the DIY event. That's a lot of money to save with this kind of project.
I have attached a sketch my uncle made to show the proposed front layout. The screen is planned to be 100". You can see some questions he has. I am thinking the center channel would be better on the shelf than above the screen so the tweeter is closer to ear level. Also, the enclosure on the right to house the tower speaker is a no go, right? I think he put that there since kids will be running around most of the time, but I'm guessing speaker grills will be protective enough.
Hopefully this can generate some interest & discussion; feel free to give any input!
Back story:
