I bought some RS180 drivers and when I went to use them I found that about 3 inches worth of surround had become unglued or was never glued on one of them. I called PE and they said "Keep it. We will send you another.". Thanks PE! Now the driver is in perfect shape. What would you use to glue the rubber like surround to the cast frame? Any ideas? I am sure someone has done it and I don't think garden variety rubber cement is the way. Thanks.
Chuck
Chuck
