First a little background-
I recently built a pair of Modula MTs and bought a Panasonic SA-XR55 receiver to drive them. When I lived on my own, I listened to probably 80% movies and 20% home theater. In the time since I finished this stereo setup, that Netlfix and my girlfriend have reversed that ratio. It was a big step up from the TV speakers.
I walked into the local CompUSA to check out some laptops when I was stopped by an 80" flat panel TV with a surround setup. I never really thought about it before, but I sat down and listed while The 5th Element was playing. Those rear surround channels really did add to the immersion!
I had a couple of NS3-193 Aurasound speakers sitting around, so I walked over to the local OSH and picked up two 35" lengths of 4" ABS pipe for $4.50 each. I didn't have to cut anything myself, just clean them off to get the dust off.
I used a hole saw and then jig saw to cut some donut shapes out of some scrap HDF I had sitting around, and cleaned it up with a rasp. I held the HDF donuts on top of the pipes with black duct tape, and then got a good seal all the way around the NS3-193s with some clear packing tape.
The pipes were definitely boomy until I stuffed them with Polyfill, but once I tweaked that around they took on a nice neutral character from the midrange down through the bottom of their range. The really strange thing was that the treble sounded like someone was talking through a fan. It turned out that they beam straight up, and the ceiling fan was what was causing the problem.
I have them highpassed on the receiver at 200 hz, and I plan on experimenting with an inductor in series similar to how Linkwitz did with his surrounds.
