I know this is going to sound entirely dumb, but when I was mounting my driver to my enclosure, I ran into two area's where I guess the screw did not make (full) contact with the wood. When I try to remove those screws, they don't want to come out... Does anyone know a good way to take the screw out without taking the whole driver out? The screw is making a rattling noise when I'm listening to the sub at louder levels.
How to remove a loose screw?
Have you tried a magnetic head screwdriver? Can you get the head above the lip of the frame? If you can you may need to get a small device under the head to put some upward pressure on it as you turn the screw, be careful not to slip.Robert P. 8)
AKA "Soundgravy"- Bottom
Better yet, if you have some 5 minute epoxy, just fill the hole with that. Its tougher than wood.- Bottom
Originally posted by mrogowskiBetter yet, if you have some 5 minute epoxy, just fill the hole with that. Its tougher than wood.- Bottom
Either will work. I'd use the toothpicks but also apply a drop of wood glue in the hole.
Pete- Bottom
