Guys, I'm about to start a dual sonosub build, and I need to have what I've come up with sanity checked (not that building two sonosubs is sane) and hopefully get some suggestions.
On a whem, I snagged about 78" of 24" Sonotube. So I've been modeling 24" x 38.5", which comes out to about 260 liters after end caps/port/driver. I've plugged the specs for the Sound Splinter RL-p15D2 into WinISD 0.44 and tuning for 16Hz, so I'm at 6" x 27.25" port tube.
I've got a Klipsch SUB12 now, which I consider decent, since it's the only sub I've ever owned.
Am I on track here? Am I tuning too low? Should I be looking at different drivers? Are my calculations off?
What's missing from my plan is the amp. I'm not sure if I want to go with panel amps on each sub, or a rack component. How many watts is it going to take to really get these drivers rockin?
Thanks for any and all advise in advance.
Kevin
Kevin
