First cuts made today
  • Newfiestang50
    • 52
    Well I finally made my first cuts today after a long process of reading all the info I could find on here, plus saving up the cash to buy a router, bits, and a circle jig. I have never used a router before but through careful measurement I managed to achieve a perfect fit with the baffle and top plug, very tight fit but after using a 1/8" roundover it fits perfect. Tomorrow I plan on recessing the driver and cutting the hole for the 6" port for which I plan to use sonotube. I am aiming for tune between 15 and 16 Hz so I believe I will need it cut approx. 33". The one problem I do have is that my jig will not allow me to cut a circle smaller than 10.5" so I have to come up with a way to rout a 6" hole, any ideas will be greatly appreciated. Oh, by the way, I plan on an enclosure size of 250 effective litres using 20" sonotube, and the driver is the very well known SS RL-P15 D2.
    Also guys, I would really like to thank all the experts on here for your free information, specifically ThomasW, Seve Callas etc. and all the others, you don't know it but you guys have helped me alot and i'm not even finished yet, thanks.
    Some pics: Images not available
    Last edited by theSven; 25 June 2023, 22:14 Sunday. Reason: Remove broken image link
  • dynamowhum
    • 260
    Congratulations on the new sub. You might look into a Jasper jig 200 it did the whole for my 15" sub and my small tweeter. Pretty broad range. Good luck with the rest of the build.
    • Paul H
      • 904
      Originally posted by Newfiestang50
      ... The one problem I do have is that my jig will not allow me to cut a circle smaller than 10.5" so I have to come up with a way to rout a 6" hole, any ideas will be greatly appreciated.
      Unplug your router and turn it upside down. Carefully measure and mark on your router base plate an X exactly 3" from the far side of the router bit you're using (rotate your router bit slightly to get the far side of the cutting edge as far away from the X you're about to mark as possible, then measure and mark).
      Now find a centre pin about which your router will be able to rotate - piece of a nail, leftover piece of a bolt, small pin inserts for shelf supports - whatever you've got around.
      Drill a hole to suit the pin at your X in your router baseplate. Drill another hole at the centre of your hole you want to cut. Insert pin in baseplate, place router so pin goes in centre hole, and make copious dust.
      I use scrap lexan for router baseplates, which hold up well to drilling full of holes and knocking around. Acrylic baseplates, which the routers are often supplied with, must be treated with kid gloves, as many who have accidentally cracked their router baseplate can attest.
      • Newfiestang50
        • 52
        Sounds like an excellent idea, I'll give it a try tomorrow, thanks.
        • Jerm357
          • 69
          Great start. I just finished my RL-P15 build, I shot closer to 240l and a slightly higher tune of 17hz. Your gonna love how these things sound in the right enclosure :B What are you going to use to power this beast? BTW Heres a link to my build, have a look.
          • nick77
            • 88
            I used the same jig you have also, great for large circles but worthless for small holes. I just used a jigsaw to complete port hole. 20" sono and 6"port at 28" tuned to ~16.7hz w/RLP-15.
            • Newfiestang50
              • 52
              http://www.avsforum.com/avs-vb/showthread.php?t=722363
              Right now I am going to use a spare NAD C272 bridged to provide 400watts into 4 ohms, I know it is probably a little short on power but it will have to do for a while until some more cash is available to buy the behringer ep-2500.
              I hope I am pleased with the sound since I have commited to sell my B&W ASW675 which is a really nice sub but I feel it it overpower by my mains, PSB Stratus Gold i.
              • kano32
                • 56
                Can't wait to see your results. I am still trying to decide if I want to do a sonosub or an IB. Keep us posted.
                • JorgenMan
                  Router base plate holes
                  by JorgenMan
                  I've got a Mastergrip router (from Costco). I think the design is the same as one of the Craftsman models, but I'm not sure. I would like to know so that as I search for accessories for my router (like the Jasper Jig), I can be sure it will fit my router. If I knew it was the same as, say, the Sears...
                  19 January 2007, 15:43 Friday
                • Ray_D
                  New circle jig and driver cutout approach
                  by Ray_D
                  I have been using a Jasper jig for several years and have found it less than terrific. I looked at the Router Buddy; but, it had some of the same issues and was expensive. So, I decided to make my own. First, I tried an approach that Pete Mazz posted several years ago that used a bushing guide and...
                  06 January 2010, 18:53 Wednesday
                • snmhanson
                  Router went astray
                  by snmhanson
                  I was routing the outer ring for a set of surrounds and my router jumped off the jig and took out a nice chunk. After recovering my composure I decided that I am going to salvage this speaker and get it done. Any suggestions on how best to do a repair here. I realize I will never be able to match...
                  15 May 2012, 12:37 Tuesday
                  Chuck's Statements 7.1 Build
                  by impala454
                  29 July 2008, 01:52 Tuesday
                • vinceb
                  Improved Router Circle Cutter (pics)
                  by vinceb
                  Or at least compared to my last attempt it's improved. I was about to order a working one and read some comments and some of the issues were things I had trouble with already, so why pay $$ and still have issues? Maybe this will be helpful to someone, so far I think it will take care of my circle...
                  24 January 2009, 21:04 Saturday
