Guys, I have everything needed to start my sonosub but I can't find any information on here about the process used for cutting the sosotube. Does anyone have a trick to accurately cut this stuff? If so please chime in. Thanks.
HELP, Cutting Sonotube
Tags: None
I cut an endcap that slides inside the tube and tack it in place. I use a carpenters square to ensure the endcap is perpendicular to the tube. Then use a router and a flush-cut bit.....that makes a perfect cut every time.
Looks like this when you're doing it....
When you say "tack it in place" do you mean with a brad nailer, and if so how hard is it to get the end cap out after? Seems to me like you would have to tear the nails through the sonotube.- Bottom
Let's put our thinking caps on.......
If you want to remove the end-cap use a few small screws to hold it in place, and back them out after the cut is completed.
The other technique is circumscribe the tube and cut it with a jigsaw.
Rockler sells a nifty flat tape measure designed for wrapping around a cylinder. There's also a thing called a 'pipe-tape' it's a wide flat rolled up piece of very thick paper/plastic that one unwraps around the tube and is used to scribe a line.
I use the builder's / painter's paper in the paint section at HD/Lowe's. They come in 3' and 6" widths IIRC. Get the smaller width (or any stiff roll paper) and wrap it around the tube and make the ends meet - the edge of the paper defines your cut line. Cut with a jig saw.- Bottom
El Nino gave you the good tip. I used a roll of gift wrap. Like he says, wrap the paper around and if the overlapped edges are in alignment, that "cut edge" will automatically give you a cut end that is perpindicular to the tube sides. Now you need Patrick Sun, covered in MDF dust, to give you some more tips.- Bottom
Thanks guys, I will give the builders paper a try as soon as my sonotube arrives on tuesdsay. Can't wait to get started, that SS RL-p15 is just begging for an enclosure.- Bottom
I would like it noted that, since Hank admitted I gave a good tip, he has lost all rights and privileges to henceforth call me "full of shit"- Bottom
Hey be nice now, or I'll forget to swing by your place on my room acoustics measurement tour of Austin- Bottom
