Hi all sorry for the ignorant post, but I'm having issues with something small on the Nat/Modula design.
I went ahead and bought the pe enclosures for the project. My trouble is getting the correct measurements for the driver cutouts. Not the actual cutouts themselves, but where the pilot holes go to use a jig and router.
My first set of baffles I measured from the back (taking into account the lip) and then drilled the holes. I then routed the circles and not one lined up, and the tweeter was not centered between the drivers.
Basically my question is how do you get precise measements on the baffles of the pe enclosures with the roundover already there and the inside plate not being totally square on the baffle (at least mine weren't)? I'm sure it's simple but I am so frustrated now I can't even figure out how to do it.
My second set of baffles will be here monday for me to ruin I mean cutout
Sorry for the dumb question, and thanks,
Derek
Derek
