I'm new to these forums, and fairly new to DIY audio. I've done some car audio and know the basics but none of the complicated theory. I'll need some help on crossover design and such.
Anyway, what I'm looking at doing is a complete home theater setup for under $1,000. This means speakers and receiver. I'm also looking at keeping the speakers fairly compact and the sub "hidden".
Here's what I got:
-- Speakers (X5) --
Tweeter: Seas 27TBFCG (~$30) [link]
Mid: Dayton DA135 ($14) [link]
Box, parts, XO: (~$30)
This will provide a set of speakers for <$75 each. Plus they will be fairly compact with the 5.5" drivers. I decided to get a decent tweeter because it has a big impact on the sound quality.
-- Subwoofer --
Woofer: Dayton DVC385-88 ($130) [link]
Plate Amp: Dayton SA240 240W ($110) [link]
Box, parts, etc (~$90)
This will provide a nice low-end for a reasonable price. Plus I plan to spend a little more on the cabnet design to make it a table/receiver cabnet. My receiver can sit inside and I can put my center and other things on top.
This puts me at around $700 for all the speakers. That leaves me with around $300 for a receiver. I'm not sure what to get for a receiver yet... or what watt I should be looking for per channel.
I want your suggestions on this setup, including speaker recommendations and receiver recommendations. I don't really want to go for a higher price on the speakers and I want them fairly compact.
I was originally thinking of some much higher-end speakers but I can't afford that stuff, especially when you start multiplying it by 5 So I decide to cut back a little on my initial design and keep it reasonable. I was looking at more of a budget sub setup but thought it wasn't worth it to save $100 buck and have something with a much lower "ability".
Also a few notes about my setup...
My room this will be used in is around 12' X 12', with the left side openning into a larger rec area. So it's like the following where the X's are in the 12' X 12' area that my home theater will be, and the left part of the room is a larger open area. I'm sitting along the bottom wall, facing the top wall.
How's that for art
I will also have a projector displaying about a 110" picture that pretty much fills that top wall and a HTPC to control this all. he he :lol:
So, if you have speaker suggestions, take into account the room setup. Also note that I will be placing the speakers near walls, so when we get more into the box and crossover design, that will have to be taken into consideration.
Thanks!!!!
Here's what I got:
-- Speakers (X5) --
-- Subwoofer --
PHP Code:
| |______
| XXXXX |
| XXXXX |
|_________XXXXX |
Thanks!!!!
