Volume of RL-p15
  • palmtree
    • 41
    Volume of RL-p15
    How much internal volume does the RL-p15 take up when installed in a box with 3/4 inch walls? Or how can I figure it myself?
    • 5204
    The soundsplinnter wesbiste says 0.21cu ft. Look down at the second third box on the right. It says "displacement".
    • palmtree
      • 41
      Ok. So is that what I use? Do I need to try and figure out how much of that volume is actually iside the enclosure or is that already figured in? Thanks Ryan.
      • dyazdani
        • 7032
        I believe that's already figured in, that's the number I used for my model as well.
        Danish
